Viewing checking results is available in all Solibri Desktop products.
Checking is available in Solibri Advancedand Premium, with full editing access.
Only the predefined rulesets created for Solibri Essential can be rechecked in Solibri Essential, Advanced, Premium.
This article describes how you select a role and rulesets before you proceed to checking in Solibri. This automatic role selection dialog opens only if you haven't set a default role for the project in Roles and if you have marked the Show role selection checkbox in General Settings. For more information on roles, see here.
If a role has been set, you can see it in the lower right corner of the status bar.
If you open the Checking layout and a dialog box opens prompting you to select a role, you need to select a role and rulesets to be used in checking:
To select a role and rulesets :
Select a role from the list. You can see more information about the role and the type of tasks that it can be used to perform the Description field (if the roles author has defined this).
If you regularly use the same role, you can choose to save it (once selected), mark the Save as Default Role box.
Click Next.
Default rulesets to be used in checking are suggested to you. Each role can have its own set of default (highlighted blue) and additional (not highlighted) rulesets. The default rulesets are suggestions, and you can de-select them by clicking on them. Additional rulesets can also be selected.
The Add Rulesets option is only available for Super Users. For more information on user profiles, see here.
Select the rulesets you wish to use.
Click OK.
