Viewing checking results is available in all Solibri Desktop products.
Checking is available in Solibri Advancedand Premium, with full editing access.
Only the predefined rulesets created for Solibri Essential can be rechecked in Solibri Essential, Advanced, Premium.
This article describes the two options for checking thta you are available in the Checking view: Check Model and Check Selected. The Check Model option allows you to run checking on the entire model, ensuring that all components and elements meet the requirements. On the other hand, the Check Selected option enables a more focused approach by only applying checks to the content currently in the Selection Basket. This flexibility allows you to perform comprehensive checks across the whole model or zoom in on specific elements for targeted analysis, depending on the project's needs.
If you use Check Model, you can subsequently filter the results with the Selection Basket tools. If you use Check Selected, results will be provided only for the elements in the Selection Basket.
If you wish to check all the models you currently have open in Solibri, you can do so with the Check Model option. Note that if the model is large or includes a lot of complex geometry, such as polygons, checking may take a significant amount of time.
To check the entire model:
In the Checking view, click Check Model:
The progression and status of checking are shown in the Checking view:
When the checking is completed, the checking results are marked with symbols indicating the status of each rule. For details, see Viewing Checking Results.
You can check parts of the model by adding components to the Selection Basket and then checking only the selected components. In this way, you can focus on specific areas in the building that require detailed attention. The checking results will show only results related to the selected components.
To view the content of the Selection Basket, add the Selection Basket view to the Checking layout.
To check the selected components:
Add the components to the Selection Basket.
In the Checking view, select Check Selected:
