If you have a project created on a BCF server and you're using BCF Connector, you can import the issues to Solibri. To import issue slides from a project on a BCF server, you need to create a new presentation with the imported issues as slides:
Go to the Communication layout.
In the Presentation view, click New Presentation. A dialog opens.
Enter the presentation name. Select From BCF Server and click OK:
A dialog opens. Select the BCF server and the project. If you need to add a server, see About BCF Connector. Click OK:
A dialog opens. Mark the checkbox for adding new issues. Click Sync Now:
A dialog opens. Select the filtering you wish to use and click OK:
The import starts. When the import is complete, you will see a synchronisation report. To close the dialog, click OK.
You can see the presentation in the Presentation view.
