BCF Live Connector is available in all Solibri Desktop products.
In the BCF Live Connector settings, you can set the automatic synchronization on or off and select if the current 3D viewpoint is automatically added to each new issue you create. To access the settings, click File > Settings > BCF Live Connector.
Use automatic synchronization: When selected, Solibri synchronizes BCF Live issue details fields without user input and disables the 'Mark as Ready' button. When the setting is off, you need to mark each issue as ready before the synchronization starts.
Add viewpoint upon new issue creation: When selected, Solibri adds a new viewpoint to the issue upon creation automatically.
Use IFC header for filenames: When selected, the name specified in the IFC header (IFC File Name.NAME) is used to identify IFC files. Otherwise, the name of the file that was imported is used. This setting is available in v9.13.8 and newer. By default, the setting is on.
