Viewing checking results is available in all Solibri Desktop products.
Checking is available in Solibri Advanced and Premium, with full editing access.
In Solibri Essential, only predefined rulesets can be checked. These rulesets can be rechecked in Solibri Essential, Advanced and Premium.
In Checking Settings, you can select the information included in the default description of an issue. The default description can be added to the Description field in the Issue Details view.
To access the settings, click File > Settings > Checking.
Restore Default Settings
Default Description content:
Select all the options to give the maximum amount of information possible.
Rule Name: Adds the name of the rule.
Rule Description: Adds the description of the rule, if the rule has one.
Categories: Adds the name of the result category.
Issue Name: Adds the title of the issue.
Issue Description: Adds the description of the issue from the Description tab in the Info view.
To add the default description using automatic text, use the button highlighted below in the Issue Details view:
Gatekeeper Rules:
Hide gatekeeper rules after checking: You can select to always hide or show gatekeeper rules after checking. By default, this setting is ON (gatekeeper rules are hidden after checking). For more details on gatekeeper rule behaviour, please see here. This setting is available in available in v9.13.3 and newer.
Default Location: * Version 25.12
To change the default location of issues in Issue Details view, it is possible to select from different options:
Nearest spaces and floors of components
Spaces clashing with components
Floors of components
Disable location
Score:
Enable Score: When selected, the Score layout is added to the set of layouts. The Score view will also be available in the list of views you can add to layouts. Note that you need to restart Solibri for the setting to take effect. This setting is available in v24.9.0 and newer.
