In Footprints Settings, you can configure settings for Model Footprints. You can also select to show or hide drawings by default.
To access the settings, click File > Settings > Footprints.
The footprint settings dialog has four tabs:
Restore Default Settings
On the Space Info tab, you can control if space info is shown by default. You can also set the text size and color, and define the data shown in space info.
Show space information: When checked, space information is shown.
Minimum/maximum text size: Set the minimum/maximum text size for space information.
Text color: Set space info text color. To change the color, click the color box. A dialog opens. Select the color and click OK:
Rows 1-3: You can define the data shown in the space info. The information selected in rows 1-3 is shown when you click the Show space info:
To add a new property, click
. A dialog opens. Select a property and click OK:
On the Grid tab, you can select if the grid is shown by default. You can also set the text size and color, and line color, thickness and transparency.
Show grid: Show or hide the grid in model footprints.
Text size: Set the size of grid labels.
Text color: Set the color of grid labels, Click the color box and select a color from the Color Chooser.
Line color: Set the color of grid lines. Click the color box and select a color from the Color Chooser.
Line thickness: Set the thickness of grid lines.
Line transparency %: Set the transparency of grid lines.
Show Intersection Lables: Show or hide labels at grid intersections (V26.4).
On the Lines tab, you can select if component footprint lines are shown by default. You can also set the line color, thickness and transparency.
