This rule checks that space names, ANSI/BOMA Space Categories, and PBS Space Types are consistent.
Space Names and Required Categories: The rule checks all spaces with the name set in the Space Name Column. The ANSI/BOMA Category and/or PBS Space Type has to be the set ones. E.g. PBS Space Type has to TTO for all spaces with name OFFICE.
It is possible to set a space requirement that the condition is valid only, if the space is surrounded by floor common and building common spaces. This is the case for multi-story office spaces, if the upper portion of the space (named as OPEN TO BELOW) are surrounded by building common and floor common spaces. In this cases the ANSI/BOMA Category should be 4 - Vertical Penetration, and the PBS Space Type should be CRV.
Analyzing the Results
The rule creates issues for each space with non-consistent property values. Issues are collected to categories so, that all spaces with the wrong ANSI/BOMA Category are collected to the same category and all spaces with wrong PBS Space Type are collected to the another category.
Reported Data
Rule Tools
The rule has no tools.
