Solibri offers various integration options to help users create an efficient workflow and manage their construction projects better. It interfaces with the most important CDEs and Issue management platforms, such as BIMSync, Autodesk Forma (BIM 360), or Dalux. The integrations enable efficient model management and collaboration by offering one source of truth for all project files and an easy way to manage model issues. In turn, this leads to improved communication, streamlined workflows, and better project outcomes.
In addition, we offer an add-on for Archicad and Vectorworks.
Please find the currently supported integrations below:
Issue Management Servers is available in all Solibri Desktop products.
The following issue management serves are available as public connections in Solibri's BCF Live Connector:
Aconex
BIMCollab
Bimplus
BUILD 365
Catenda (former BimSync)
Dalux
Newforma (former BIMTrack)
Pillr
Poolarserver
StreamBIM
Trimble Connect
Common Data Environments (Model Management) is available in Solibri Advanced and Premium.
The following common data environment (CDE) integrations are available for model management:
With Solibri's Autodesk Forma / BIM 360 integration, you have access to the latest information directly from Solibri. You can open, save and update models in your projects without saving the model files locally. The BIM 360 integration is available in Solibri v9.13.1 and newer.
The Documents API integration offers an easy way to access your cloud-stored content. You can connect to a common data environment (CDE), and download and upload models from or to the server. As a result, you always have access to the latest available information. The Documents API integration is available in Solibri v9.13.0 and newer. You can connect to the following CDEs via Documents API:
Aconex
Bimsync
Buildercom
buildagil
Catenda
Trimble Connect is a collaboration tool offering up-to-the-minute, construction-ready project information. With Solibri's Trimble Connect integration, you can open, save and update models in your projects without saving the model files locally. The integration is available in Solibri v9.13.5 and newer.
Other Integrations are available in Solibri Advanced and Premium.
The following add-ons are available:
Archicad
The Archicad-Solibri add-on automatically detects and sends only those elements that are changed in the Archicad model, allowing a faster collaboration. BCF-based issue reporting has also been introduced to this workflow, enabling designers to assign the detected issues or solve them later on. The add-on allows fast BIM updates and the use of Solibri while working in a real time design scenario. More information and instructions how to download here.
Vectorworks
The two-way live-sync between Vectorworks and Solibri creates a live link between a Vectorworks BIM model and its corresponding IFC model in Solibri. More information here.
