Using the Autodesk Forma/BIM 360 Integration is available in Solibri Advanced and Premium.
This article describes how you can connect to the BIM 360 construction document management software. With Solibri's BIM 360 integration, you have access to the latest information directly from Solibri. You can open, save and update models in your projects without saving the model files locally. The BIM 360 integration is available in Solibri v9.13.1 and newer. Please note that the integration is not available in Solibri Starter and Essential.
Additionally, you can use the BIM 360 integration to connect to your Autodesk Forma projects.
You can open the following file types in Solibri using BIM 360:
Model files:
DWG
IFC & IFCZIP
PDF
SMC
ZIP
In v9.13.8 and newer, you can also open and save resource files, which allows you to access and manage resources more effectively within the integrated environment.
You can open and save the following resource files: rulesets, ITO definitions, classifications, filters, BCF files, Excel reports and templates, hierarchies, materials, and IDS files
You’re able to store and manage presentation reports, including BCF reports, general reports (RTF, PDF), coordination reports (Excel), and ITO reports, within the integrated environment
To connect to BIM 360 from Solibri, you need to have a BIM 360 account.
Before you can connect to BIM 360 in Solibri, your BIM 360 account admin needs to enable the Solibri integration via the BIM 360 app store. The admin needs to:
Once the admin has enabled the integration, you can go to Integrations in Solibri and connect to BIM 360.
When you have enabled the BIM 360 connection, a BIM 360 tab will become available in the file chooser. You can open one or multiple files from the CDE at once. Opening multiple files works for .ifc, .zip, .ifczip, .dwg and .pdf files. You can't open multiple .smc files, but you can open, for example, an .smc and a .ifc file.
To open files from BIM 360:
Click File > Open Models. A dialog opens. Select the BIM 360 tab.
Select the server (EMEA/US) from the Server drop-down menu:
Select your project from the Project drop-down menu:
After selecting the project, navigate to the desired file or folder below.
In the file chooser, you can see the different files and sort them by Name, Version, Size, Last updated and Updated by by clicking the column heading:
Double click the file (or select the file(s) and click Open).
The model opens in Solibri. For more information on the next steps, see Setting Model Short Name, Discipline and Category.
Additionally, Solibri shows the BIM 360 files in the Recent Models list, as well as the Recent tab inside the Open Models dialog.
If you have already opened an SMC file, you can only add more IFC files (not open another SMC file).
When you open a file from BIM 360, you can see the file version number in the Model Tree view:
You can only save SMC files into BIM 360. To save models into BIM 360:
Click Save (if saving for the first time) or Save As. A dialog opens. Go to the BIM 360 tab.
If you have opened the file from BIM 360, the file chooser remembers the project. If not, first select the server and project and then navigate to the correct file location:
Select the file location and click Save or Save As.
If you disconnect the integration, Solibri displays a warning which suggest that you save your progress before disconnecting.
You can update imported IFC models with new versions directly from BIM 360. You can select to update either a single IFC model or several IFC models at once.
Note that if you update models, you need to manually re-check the model to update the checking results. Issues that are not affected by the update keep their decisions, comments and snapshots. You can see the updated model in 3D when an issue is selected. You need to update the snapshots and other details in issue slides manually.
To update models from BIM 360:
Select a model/models in the Model Tree view. Right click and select Update Models from the context menu:
Alternatively, click File, then Update Models. The dialog below will then list all the opened models and you can select which ones you wish to update.
The Update Models dialog opens:
Select one of the three updating options:
Update: Requires you to manually carry out this task when you want to update any models. If the filename has changed (revision letter, date etc.) then the new version of the file will need to be located using the Folder icon (
) at the end of the row. This will need to be done for each model.
Automatic: Updates are done automatically in the background when the software is started, and during a session if the time stamp is changed. Make sure that the new version of your file(s) is located in the same folder where the original model file is, and that it has the same name. The software will update your model automatically.
Prompt: You will get a prompt when the update is available, and the updating starts at your convenience. Make sure that the new version of your file(s) is located in the same folder where the original model file is, and that it has the same name.
When you click
, the File Chooser dialog opens. On the BIM360 tab, go to the correct file location, select the file and click Open:
Click OK.
After any update or change to the Model Tree structure (such as adding or removing IFC files), Solibri will notify you of unsynchronised results. You will also notice that:
The rulesets are greyed out and reporting is disabled
Result Summary view is blank
The Results view shows the following message advising to run the check again: "Some models have been modified since the last check is done, please run check to see the results."
To proceed, you must click Check Model/Check Selected to run all the checks again.
Our custom Forma Issues integration now supports pushpins bidirectionally, meaning that your Solibri issue locations and camera settings are reflected in Forma and vice versa. As the connection is custom and not BCF compliant, there is some setup and minor limitations to consider:
Forma Project Setup
When setting up a project, ensure the following:
The Forma project must contain specific folders to save Viewpoints.
Custom fields must be configured and mapped to the issue types in Forma.
The models opened in Solibri are directly opened from Forma. This ensures that the link between Solibri and Forma remains, and that pushpin placement can be handled correctly.
For details about the required custom fields, the viewpoint folders and other setup information related to Issues see Using the Autodesk Forma/BIM 360 Server Connection.
Performance & Component Limits
Component Count: To keep the connection performant, if there are more than 5,000 components in an issue, the view will be saved without any isolation or other view-related modifications (everything will be visible).
Workaround: Make sure your views are zoomed in enough to keep the component count down.
Character Limits
Title: Forma has a limit of 100 characters
Description: Forma has a limit of 1,000 characters
Exceeding these limits will trigger a sync error, which can be resolved by reducing the character counts.
Note: Unfortunately, there is no meaningful messaging available through the Autodesk API at the moment to inform users of this, so it is simply something that needs to be kept in mind.
Automatic Pushpin Behavior
Solibri creates pushpin locations based on camera angles (by shooting a ray to where the camera is pointing).
This means that in some cases, the actual pushpin location may not be exactly where the user intended it to be.
If the camera angle does not end up meeting any component, the viewpoint will not be stored.
Model Coordination Selection
To visualize models in Forma which are relevant to your work, it is recommended to use Model Coordination spaces and views. This approach allows you to open selected models in the Forma viewer and save views either privately or publicly for the wider project team. From these views, you can access Issues directly via the left-hand panel. For best results, ensure that the IFC models loaded in the SMC model align with the corresponding views in Model Coordination.
If you're utilizing model coordination views, upon connection in Solibri, make sure to select the correct model coordination view. This ensures that issues get synced to the right destination.
Other limitations:
Currently, in some cases Forma viewer primarily respects the view related settings (hiding and isolation of components) for the model on which an issue’s pushpin is placed, and hides all other models in the view. This means that view-related settings apply solely to the model containing the pushpin, while additional models in the coordination view are not shown when that issue is opened. Autodesk is aware of this limitation in the current implementation and has indicated that they are working on improving the behavior in a future update.
