This rule checks that running meters of shelves. Rule also creates a report all storage spaces with their shelf running meters.
Space Classification:
Classification used for classifying spaces. Classification names are set in the Classification Name column of the Storage Spaces and Shelf Running Meters table.
Storage Spaces and Shelf Running Meters:
The table has columns to space identification and a column for required amount of shelf running meters in specified spaces. You can specify spaces to be storage spaces with space usage classification, name, type and/or number. You can leave any of the cells empty. Use the one that best fits your case and the information that you have in the model.
Space in Front of Doors:
Required free space in the front of the doors in storage spaces.
Horizontal Spacing:
Required free space between shelves in the storage.
Vertical Spacing:
Required vertical free space between those shelves.
Shelf Depth:
Required depth of the shelves.
Bottom most Shelf Elevation:
Required elevation of the lowest shelf.
Topmost Shelf Elevation:
Highest accepted elevation of the topmost shelf.
The rule creates an issue of all storage spaces, whose calculated shelf running meters is less than required. The calculated shelves are visualized together with the space.
The rule has a report about calculated shelf running meters of all storage spaces in the model.
The rule has a Tools View for visualizing the shelves in building or in a specified floor.
