Creating Reports from Presentations is available in Solibri Essential, Advanced and Premium.
This article describes how you can create BCF, PDF, RTF and spreadsheet reports from presentations you have created in Solibri.
To create a report from a presentation, go to the Communication layout.
BCF (BIM Collaboration Format) is a format that several BIM authoring tools support. It allows you to communicate the results directly back to the authoring software to be fixed. BCF format contains all data from the the issue details, camera location and target of the view created, and the PNG of the views. BCF tags the related components to easily identify and select them in the authoring tool.
To create a BCF report from a presentation:
To create a general report from a presentation:
Select General Report (PDF/RTF) as the report type.
Optional settings: To control page format, orientation and margins, click Page Setup. A dialog opens. Determine the settings and click OK:
To balance between the report size and image resolution, select image quality (high, medium, low) from the drop-down list. With large reports containing many issues, this can make a significant difference to the file size.
Click Save report.
Select the destination folder and click Save As.
To create a coordination report from a presentation:
Select Coordination Report (Excel) as the report type.
Select the report template. You can use the default template or create your own. You can see the list of keywords used in the report below.
Click Save report.
General keywords can be added to different rows. One cell can include more than one keyword:
Table 20. General keywords
Keyword |
Description |
Place to Edit |
<PNG_IMAGE> |
Logo or other image |
Insert a PNG/JPG image into the template |
<REPORT_TITLE> |
Title of the report |
<FILE_NAME> |
Name of the model file |
<SOLIBRI_VERSION> |
Solibri version number |
<USER_NAME> |
Solibri user name (email) |
<USER_ORGANIZATION> |
Name of the organization |
<CURRENT_TIME> |
Timestamp for report creation |
<EMPTY> |
Used for marking empty cells |
Model keywords are related to the model files included in the report. They must all be on the same row. One cell can include multiple keywords:
Table 21. Model keywords
Keyword |
Description |
Place to Edit |
<MODEL_NAME> |
Name of the individual model file |
<MODEL_TIME> |
Timestamp for model creation |
<MODEL_APPLICATION> |
Application used to create the model |
<MODEL_TYPE> |
Type of the exported file |
If there are multiple models, each is listed on its own row and has the time, application and type information.
Presentation keywords include the name of the presentation. It must be on a row of its own:
Table 22. Presentation keywords
Keyword |
Description |
Place to Edit |
<PRESENTATION_NAME> |
Name of the presentation in Solibri |
Right-click the presentation in the Presentation view and select Rename |
Slide keywords are mostly related to the Issue Details view information in Solibri. They must all be on the same row, but in different cells:
Table 23. Slide keywords
Keyword |
Description |
Place to Edit |
<SLIDE_NUMBER> |
Order number of the issue slide in the presentation |
<SLIDE_ID> |
Tracking ID of the issue slide |
<SLIDE_LOCATION> |
Location of the issue |
<SLIDE_TIME> |
Timestamp for issue slide creation |
<SLIDE_AUTHOR> |
Author of the issue slide |
<SLIDE_TITLE> |
Title of the issue |
<SLIDE_PICTURE> |
Issue snapshots. The image currently selected in Issue Details view is listed first. |
<SLIDE_DESCRIPTION> |
Description of the issue |
<SLIDE_COMMENT> |
Comments on the issue |
<SLIDE_RESPONSIBILITIES> |
Responsibilities |
<SLIDE_STAGE> |
Stage of the issue |
<SLIDE_DUE_DATE> |
Due date of the issue |
<SLIDE_LABELS> |
Labels of the issue |
<SLIDE_STATUS> |
Status of the issue (e.g. assigned, open, closed, resolved) |
<SLIDE_PRIORITY> |
Priority of the issue |
