This article explains how the Markup tool works. With the Markup too, you can add for example arrows, texts, shapes, as well as component and coordinate stamps, to your components or model to communicate your thoughts with your project team. Markups are saved in issue snapshots and can be seen in communication.
To add a markup, select the Markup tool from the main toolbar:
The Markup toolbar opens, and you can choose from the following options:
Once you have drawn a graphical markup, you can move it by dragging and dropping it. You can resize it by grabbing on the green frame with grips and stretching. Note that you can't edit text boxes, stamps and pictures.
Markups and dimensions are only saved in the issue snapshots, not in the model. They are always set along on the surface of a component. They can be resized or moved after you have drawn them, but they maintain the same direction if you move them. You can change the colour and line thickness of markups and dimension markings.
To remove markups, select from the following options:
Click
Right-click and select Remove Markups from the context menu.
Use the Hide tool and click on the markups you want to remove (except stamps).
Use Undo.
To quickly access Markup Settings, click in the Markup toolbar.
You can draw free lines, as well as add text and shapes. You can also define the color and line thickness of the markups.
Pen: Draw freehand lines and shapes.
Text: Click where you want to add a single line of text. Enter your text (maximum 40 characters) and click OK. Text cannot be edited afterwards.
Arrow: Click a start point and draw the arrow toward the target.
Line: Click a start point and draw a line.
Ellipse: Click a start point and draw an ellipse.
Cloud: Click a start point and draw a cloud shape.
Rectangle: Click a start point and draw a rectangle. (Available from Solibri 26.4)
Markup color: Define the color of the markup. Black is available as a color option.
Markup line thickness: Define the line thickness for the markup.
Component stamp: The component information is imported from the IFC file and stamped on the component. The insertion point is the centre of the image. To add a component stamp, click on a component. Stamps cannot be moved or resized. Content of the subsequent stamp can be edited in Markup Settings.
Coordinate stamp: The coordinates are imported from the location data of the component and stamped on the component. To add a coordinate stamp, click on a spot. Stamps cannot be moved.
Image: You can add an image on the model, for example on a wall. Supported image formats are GIF, JPG, JPEG, PDF and PNG. Click the spot where you want to add the image. A dialog box opens. Select the image and click OK.
Notice
Using images, especially ones with large file size, increases the file size of the model.
Selecting markups
Click any markup to select it.
Selected markups display handles for easier manipulation.
Use the Model Tree to view all markups.
To select a markup for editing, use the Edit Markup tool. If a markup creation tool is active (for example, Ellipse), deactivate it first, then click the markup in the 3D view.
Moving markups
Select the markup, then drag it to a new position.
Resizing markups
Select the markup, then drag its handles to adjust the size.
Deleting markups
Select the markup.
Press the Delete key.
You can also remove all markups at once using Remove Markups from the Markup toolbar.
Tips for best results
Choose black markup color when annotating on light backgrounds for maximum contrast.
Use the Rectangle tool to frame areas of interest in coordination reviews.
Select Edit Markup before clicking an existing markup — creation tools must be inactive for selection to work.
