To see the application and system information, such as the version and build number go to File > Help. From there, you can see the following information:
Application information: Application, Vendor, Patents, Build number and Timestamp
Installed extensions: Shows the name and version of extensions you have installed.
System information: Operating system, Java version, Java virtual machine, Java max memory and Used memory
3D information: Mode, Display adapter vendor, Display adapter, 3D interface, Supported OpenGL version and Optimized rendering
When you contact Solibri Support, it's always a good idea to include information about the product, version and build you are using. To do that, click the Copy to Clipboard button. It will capture the details shown, and you can then paste them into your support case or email.
