Changes in the rules and the associated requirements file could mean projects started with the previous version should be checked carefully in line with the changes. We recommend you make a copy of the file and test with the new rules. Ensure any new values are entered in the parameters and that you have any new sheets / columns present so that the rules function correctly.
Version 2.1.101: Released 2023/06/26
SUK/1002 V2.1 - Identity rule
Fire Seal on Wall and Floor Reduction Tolerance added to ensure services fully penetrate fire seals.
SUK/1004 v2.1 - Compatibility rule
SUK/1006 v2.1 - Distance rule
SUK 1008 v2.1 - Position rule
Bug fix - Incorrect measurement of top condition
Improved visualisation of results with added option - Show checking range in issue visualization option (default = on)
SUK/1010 v2.1 - Area and Volume rule
Fire Seal on Wall Reduction Tolerance added to ensure services fully penetrate fire seals.
SUK/1012 v2.1 - Support rule
Bug Fix - Identification of parallel services in non parallel specified fire seals (Low Severity)
SUK/1014 v1.1 - Angle rule
SUK/1015 v1.1 - Report rule
SUK/1016 v1.1 - Common Parameter rule
Version 2.0.99: Released 2023/06/13
Requirement file - Service Types Sheet (can be downloaded here)
Additional of a Mergeable gap for services to take into account modelling gaps between service components
Services Types now applies to two new rules - Angle and Report rule
SUK/1001 v2.0.99 - Stud Opening Check
Fixes incorrect position and rotation of studs when objects are a long distance from the origin.
SUK/1002 v2.0.99 - Identity rule
Common Parameter Name addition
Merge service gap parameter to ensure that services fully penetrate walls
SUK/1003 v2.0.99 - General Distance rule
Service Type with Mergeable gap
Results in line with merged Service Types
SUK/1004 v2.0.99 - Compatibility rule
SUK/1005 v2.0.99 - Proximity rule
SUK/1006 v2.0.99 - Distance rule
Compartmentation specific for walls and Floors - support based issue related to walls that were wider than tall
SUK 1007 v2.0.99 - Dimension rule
SUK 1008 v2.0.99 - Position rule
Distance to Top Compartmentation now accepts empty value for Maximum
SUK 1009 v2.0.99 - Opening and Thickness rule
SUK/1010 v2.0.99 - Area and Volume rule
Name changed to support both Gross / Net values for Area and Volume
Results in session only, copies Gross and Net values to Custom Info parameters that can then be used in the information takeoff view.
SUK/1011 v2.0.99 - Clearance rule
Inaccessible spaces changed to Accessible spaces - User to provide the list of spaces that are accessible rather than inaccessible.
Space range locater function improved
Improved results
SUK/1012 v2.0.99 - Support rule
Integration of the Angle rule functionality by way of an additional column in the requirements file Perpendicular - to check if the services are Perpendicular, Non Perpendicular or outside the angle limits in relationship to the fire seal type.
SUK/1013 v0.1 - Advanced Proximity rule - (under development)
SUK/1014 v1.0 - Angle rule - New rule
SUK/1015 v1.0 - Report rule - New rule
SUK/1016 v1.0 - Common Parameter rule - New rule
Version 1.0.8 2023/01/30 - Initial Release
