Rule ID: SUK/1009/v1.0
This article describes the Fire Stopping Opening and Thickness Rule that has been developed by Solibri UK Ltd as part of the BIM Coordination + Library.
This rule is used to check that each fire seal fits the associated wall or floor void perfectly along with ensuring that the fire seal is at least the thickness of the host wall or floor.
The rule finds all fire seal components on compartmentation walls and floors through their corresponding filters. The rule checks the top, bottom, and each side of the fire seal to ensure that the surface area touches 100% of the compartmentation void. The rule then checks to ensure the thickness of the fire seal is at least the thickness of the compartmentation.
Although only the services and fire seals filters of these rules require users to set up classifications it is good practice to also use classifications for the compartmentation. The benefits are as follows:
To structure the model geometry allowing easy identification and visualization in the classification and providing a clear indication of what will be checked
Where present, Services and Fire Penetration Seals will require classification values to interact with the FireStoppingRequirements.xlsx spreadsheet
Parameters View
In the Parameters view, you can define the walls, floors, and fire seals to check for opening and thickness requirements.
Walls filter: Defines the compartmentation walls to have fire seal opening and thickness requirements checked.
Floors filter: Defines the compartmentation walls to have fire seal opening and thickness requirements checked.
Fire Seals filter: Defines the fire seal components to have their positions checked.
The rule categorizes 3 types of critical () severity results by the Fire seal ID of the fire seal(s):
The fire seal does not touch 100% of the side surfaces of the void it is designed to fill.
The thickness of the fire seal is less than the thickness of the compartmentation.
The fire seal intersects with the compartmentation.
Severity:
