Changes in the rules and the associated requirements file could mean projects started with the previous version should be checked carefully in line with the changes. We recommend you make a copy of the file and test with the new rules. Ensure any new values are entered in the parameters and that you have any new sheets / columns present so that the rules function correctly.
Version 2.3.1 released 2025/01/16
General update
All rules that check fire seals now incorporate the ability to check hollow fire seals or sleeved style objects.
All rules that require a requirements file.
Bug fix - Path fixed, invalid characters are no longer allowed when pasting - right clicking a file and using copy as path and paste. Invalid characters removed and clear function added.
SUK 1002 v2.3 - Identity rule
Hollow Fire Seal support.
SUK 1003 v2.3 - General Distance rule
Bug Fix - Invalid characters no longer allowed and clear function added.
SUK 1004 v2.3 - Compatibility rule
SUK 1005 v2.3 - Proximity rule
SUK 1006 v2.3 - Distance rule
SUK 1007 v2.3 - Dimension rule
SUK 1008 v2.3 - Position rule
SUK 1009 v2.3 - Opening and Thickness rule
SUK 1010 v2.3 - Area and Volume rule
SUK 1011 v2.3 - Clearance rule
SUK 1012 v2.3 - Support rule
SUK 1014 v2.3 - Angle rule
SUK 1015 v2.3 - Report rule
SUK 1016 v2.3 - Common Parameter rule
SUK 1017 v2.3 - Advanced Identity rule - New Rule
Provides 6 different cases related to the current state of service that penetrates a compartmentation wall or floor.
Version 2.2.19 released 2024/02/06
Ensure you have downloaded the new Excel Template.
General Update
Excel requirement files that are updated automatically require the rules to be re-checked. (Selecting another rule or scrolling the list of rules in the checking view will render the results blank).
Reporting to log files is now kept to critical items only.
Bug fix - Issue with override and restore functions when common parameters utilised.
SUK 1001 v2.2 - Stud Opening Check Rule
Option added to use building storey height for the vertical stud.
Complex door geometry now handled differently.
Results - New category added to results to identify invalid geometry.
Bug fix - Java errors where compartmentation geometry is invalid.
SUK 1002 v2.2 - Identity rule
Partial penetrations are now separated and listed in a new category (low severity) for each compartmentation wall or floor.
SUK 1006 v2.2 - Distance rule
Fire Seal and Service Distance sheet now supports independent values for Minimum top, bottom and sides along with the existing minimum all sides value where these are not specified.
Where any of the top, bottom or side values are not specified with no minimum value for all sides the rule creates an error.
SUK 1008 v2.2 - Position rule
Results - New category added to results to identify invalid compartmentation geometry.
Bug fix - Incorrect measurement due to specific conditions.
Bug fix - Java errors due to specific conditions.
SUK/1012 v2.2 - Support rule
Perpendicular / Non Perpendicular checks now report the angles in the result description.
Additional wall type criteria added to rule - Wall classification is required in both the spreadsheet but also specified under the wall filter - Use wildcard values if not configured using older version of rule. (change of dialogue box - and spreadsheet update along with the additional parameter text).
Services that do not fully penetrate are reported for the fire seal but other parameters are still checked i.e. wall relationship checks. - Use the fire seal on wall reduction tolerance if there are many issues (show the results that indicate a partial service penetration).
Multi row evaluation - Multiple rows are now evaluated where the conditions are met from the Fire Seal, Services and Wall Types.
New categorisation based on multi row evaluation - Categorisation now by fire seal, then by issue type followed by issues for which rows have failed. Note: This will affect any existing results that have been created.
Option to show which rows have passed when the all the conditions of at least one row are met. Other failed row results are then removed.
Bug Fix - Rule changed to ensure services are fully compatible - previously once one service was matched in the list it would evaluate that row.
Bug Fix - Java issues for certain geometry.
bug Fix - Drop head distance check fixed for specific measurement condition.
SUK/1014 v2.2 - Angle rule
Bug Fix - Fix to angle calculation method.
SUK/1015 v2.2 - Report rule
Wall ID added to rule template (show new ID in template).
Wall ID added to the report (show the new column).
New report type added - based on the service - fire seal - wall.
SUK/1016 v2.2 - Common Parameter rule
Option to write all model Classification values to requirements file - reduces typo errors for classification names in the requirements file tabs.
Version 2.1.101: Released 2023/06/26
SUK/1002 V2.1 - Identity rule
Fire Seal on Wall and Floor Reduction Tolerance added to ensure services fully penetrate fire seals.
SUK/1004 v2.1 - Compatibility rule
SUK/1006 v2.1 - Distance rule
SUK 1008 v2.1 - Position rule
Bug fix - Incorrect measurement of top condition
Improved visualisation of results with added option - Show checking range in issue visualization option (default = on)
SUK/1010 v2.1 - Area and Volume rule
Fire Seal on Wall Reduction Tolerance added to ensure services fully penetrate fire seals.
SUK/1012 v2.1 - Support rule
Bug Fix - Identification of parallel services in non parallel specified fire seals (Low Severity)
SUK/1014 v1.1 - Angle rule
SUK/1015 v1.1 - Report rule
SUK/1016 v1.1 - Common Parameter rule
Version 2.0.99: Released 2023/06/13
Requirement file - Service Types Sheet (can be downloaded here)
Additional of a Mergeable gap for services to take into account modelling gaps between service components
Services Types now applies to two new rules - Angle and Report rule
SUK/1001 v2.0.99 - Stud Opening Check
Fixes incorrect position and rotation of studs when objects are a long distance from the origin.
SUK/1002 v2.0.99 - Identity rule
Common Parameter Name addition
Merge service gap parameter to ensure that services fully penetrate walls
SUK/1003 v2.0.99 - General Distance rule
Service Type with Mergeable gap
Results in line with merged Service Types
SUK/1004 v2.0.99 - Compatibility rule
SUK/1005 v2.0.99 - Proximity rule
SUK/1006 v2.0.99 - Distance rule
Compartmentation specific for walls and Floors - support based issue related to walls that were wider than tall
SUK 1007 v2.0.99 - Dimension rule
SUK 1008 v2.0.99 - Position rule
Distance to Top Compartmentation now accepts empty value for Maximum
SUK 1009 v2.0.99 - Opening and Thickness rule
SUK/1010 v2.0.99 - Area and Volume rule
Name changed to support both Gross / Net values for Area and Volume
Results in session only, copies Gross and Net values to Custom Info parameters that can then be used in the information takeoff view.
SUK/1011 v2.0.99 - Clearance rule
Inaccessible spaces changed to Accessible spaces - User to provide the list of spaces that are accessible rather than inaccessible.
Space range locater function improved
Improved results
SUK/1012 v2.0.99 - Support rule
Integration of the Angle rule functionality by way of an additional column in the requirements file Perpendicular - to check if the services are Perpendicular, Non Perpendicular or outside the angle limits in relationship to the fire seal type.
SUK/1013 v0.1 - Advanced Proximity rule - (under development)
SUK/1014 v1.0 - Angle rule - New rule
SUK/1015 v1.0 - Report rule - New rule
SUK/1016 v1.0 - Common Parameter rule - New rule
Version 1.0.8 2023/01/30 - Initial Release
