To ensure optimal performance and a seamless experience when using Solibri, it's essential that your system meets or exceeds the recommended hardware and software specifications, especially if you're handling large or complex models. Below are the recommended system requirements to help you achieve the best performance and avoid slowdowns:
Table 1. System requirements for Solibri
Processor |
Intel® Core™ i7 (12th generation or newer), AMD Ryzen™ 7 5000 series (or newer) |
Operating System |
Microsoft® Windows® 10 or 11; macOS Ventura or later. |
Graphics Card |
High performance graphics card with OpenGL version 3.3 support or better. |
RAM |
Minimum 16 GB RAM, 32 GB RAM or more recommended for larger model sizes |
Hard disk |
Solid State Drive (SSD) with several GB of available hard disk drive space is recommended |
Mouse |
Wheel mouse or similar functionality |
While it's possible to use Solibri in virtualized environments, they are not officially supported. Unfortunately we don't have official tested recommendations on what systems or solutions should be used.
