Rule ID: SUK/1011/v2.3
This article describes the Fire Stopping Clearance Rule that has been developed by Solibri UK Ltd as part of the BIM Coordination + Library.
The rule is available for Solibri Office 24.9.0.38 or later via a Solibri Extension, which can be downloaded from the Solibri Solution Center.
This rule requires connection to an external spreadsheet and the Fire Seal Clearance on Walls sheet and Fire Seal Clearance on Floors sheet. A copy of this default template for all Fire Stopping rules, FireStoppingRequirements.xlsx can be downloaded at the end of the Introduction article or through the link in the description (info view), for the selected rule in the checking view.
This rule is used to ensure that there is adequate spatial area for the fire seals to be installed.
Fire Seal Spatial requirements obstructed by wall component
The rule first checks that all components filtered as Fire Seals have their fire seal types classified by the Fire Seal Classification. The rule then finds all fire seal components on compartmentation walls and floors through their corresponding filters. Any fire seals to be checked with types from the Fire Seal Classification that are unspecified within the requirements file are returned as issues to be addressed.
The fire seals have their required surrounding clearances determined by the requirements file based on fire seal type. For fire seals attached to walls, where an inaccessible space is identified within the specified range (defined through the Accessible Space filter and Inaccessible Space Range) it only checks the side that is accessible. Fire seals that are inaccessible on both sides return this as an issue. The accessible sides of the fire seals are then checked to ensure that none of the filtered obstructions are within the required surrounding clearances required.
Inaccessible Space reduces spatial check to only one side.
In the Parameters view, you can define the compartmentation walls and floors, fire seals, accessible spaces, and obstructions to check for adequate space for the installation of fire seals.
The Services and Fire Seals filter of these rules requires users to set up classifications. It is also good practice to use classifications for the Compartmentation filter, for the following reasons:
Help structure model geometry allowing easy identification and visualization in the classification providing a clear indication of what will be checked.
Where present Services and Fire Penetration Seals will require classification values to interact with the FireStoppingRequirements.xlsx
Parameters view
The Fire Seals in this instance are using the operator Is Defined to filter all classified fire seals. This negates having to use the One of operator, ensuring that you have all fire seal values selected. Updates to the classification are also applied automatically.
Walls filter: Defines the compartmentation walls to have fire seal clearance checked.
Floors filter: Defines the compartmentation floors to have fire seal clearance checked.
Fire Seals filter: Defines the fire seal components to have their clearance checked.
Fire seals Classification: Select the classification that contains the classified fire seal types that are defined in the fire seals filter. The fire seal types column within Fire Seal and Service Distance and Service Distance in Fire Seal sheets of the Requirements file, match with classifications names from this Fire seals Classification, to define their compatibility and distance requirements of service penetrations that run through them.
Example Hollow Fire Seal
Accessible Spaces filter: Defines which spaces that the fire seal can be accessed from.
Accessible Space Outward Range: Specifies the depth in front of the face of the fire seal to check for an accessible space. This checks automatically both the outward range and the depth of the fire seal to its associated building story level in order to check spaces against the filtered accessible spaces.
Use Custom Accessible Space Downward Range: Activate the option to specify a specific downward range detecting accessible spaces.
Accessible Space Downward Range: Enter value for distance to check downwards for accessible spaces.
Obstructions filter: Defines any components that can pose an obstruction if it is within the fire seal clearance requirements.
Requirements File Path: Browse and select the spreadsheet (xlsx) that contains the Fire Seal Clearance on Walls and Fire Seal Clearance on Floors sheets used to define required spatial requirements.
Fire Seal Clearance on Walls sheet parameters:
Fire Seal Types (separated by semicolons, can contain wildcards): This cell contains the fire seal type name(s) to match from the Fire seals classification to define their clearance requirements. If multiple names are listed, those fire seal type names must be separated by semicolons (;). The use of the Asterisks (*) and Question Mark (?) and double hyphen (--) wildcard characters can be used to match names as below...
? Matches exactly 1 character
Side Offset (mm): This cell contains the distance in millimeters from the side of the fire seal that must be free of obstructions. A value is required in the cell and must be either 0 or positive numerical value.
Top Offset (mm): This cell contains the distance in millimeters from the top of the fire seal that must be free of obstructions. A value is required in the cell and must be either 0 or positive numerical value.
Depth (mm): This cell contains the distance in millimeters out from the face of the fire seal that side and top offsets must be free of obstructions. A value is required in the cell and must be a non-zero positive numerical value.
Bottom Tolerance (mm): This cell contains the distance in millimeters out from the face of the fire seal to begin checking for obstructions underneath the fire seal to the bottom of the compartment wall. A value is required in the cell and must be either 0 or positive numerical value.
Bottom tolerance set to 300mm to allow for vertical components attached to wall under the Fire Seal
Bottom Depth (mm): This cell contains the distance in millimeters out from the bottom tolerance to check for obstructions underneath the fire seal to the bottom of the compartment wall. A value is required in the cell and must be a non-zero positive numerical value.
Issue Category (empty for default): This cell contains optional text to be included in the result titles of floor position violations found for the defined fire seal types.
Fire Seal Clearance on Floors sheet parameters
Offset (mm): This cell contains the distance in millimeters from the sides of the fire seal that must be free of obstructions. A value is required in the cell and must be either 0 or positive numerical value.
Height (mm): This cell contains the distance in millimeters above the face of the fire seal that the offsets must be free of obstructions. A value is required in the cell and must be a non-zero positive numerical value.
The rule results fall into two categories:
Fire Seal ID
The rule creates categories using the values from the property defined in the Fire Seal ID Property Reference parameter. These categories group fire clearance violations by their specified Fire Seal ID:
Critical (
) severity results are listed where:
Clearance in wall requirements for the fire seal type are unsatisfied - Clashing with obstructing components
Clearance in floor requirements for the fire seal type are unsatisfied - Clashing with obstructing components
Wall based fire seals are inaccessible from both sides
Moderate (
) severity results are listed for fire seals on compartmentation walls to be checked and classified with fire seal types in the Fire Seal classification but are missing a corresponding row for those types in the Fire Seal Clearance on Walls sheet of the requirements file.
Moderate (
) severity results are listed for fire seals on compartmentation floors to be checked and classified with fire seal types in the Fire Seal classification but are missing a corresponding row for those types in the Fire Seal Clearance on Floors sheet of the requirements file.
Unclassified Fire Seals
This category has a single low (
) severity result listing all components filtered by the Fire Seals filter parameter table to be checked but are missing their fire seal type classification in the Fire Seals classification.
Controlling the Issue Title:
Illustration of the title components
Severity:
