Rule ID: SUK/1010/v2.1
This article describes the Fire Stopping Area Rule that has been developed by Solibri UK Ltd as part of the BIM Coordination + Library.
The rule is available for Solibri Office 9.13.3 or later via a Solibri Extension, which can be downloaded from the Solibri Solution Center.
This rule is used to indicate gross and net area / volume taken up by each fire seal and its associated services.
The rule first finds all fire seal components on compartmentation through their corresponding filters. The rule then finds all pipes, ducts, and cable carriers that intersect the fire seals, returning these as results to report the gross and net areas and volumes of the fire seals. Calculated values displayed in the results description are transferred to custom info parameters for each fire seal, which can be used in conjunction with the Information Takeoff for reporting purposes.
In the Parameters view, you can define the compartmentation, fire seals, pipes, ducts, and cable carriers to report gross and net area of fire seals. Alternatively use a predefined Common Parameter Name configuration to consistently utilise the same values for parameters within multiple fire stopping rules, essentially configuring the values only once.
The Services and Fire Seals filter of these rules requires users to set up classifications. It is also good practice to use classifications for the Compartmentation filter, for the following reasons:
Help structure model geometry allowing easy identification and visualization in the classification providing a clear indication of what will be checked.
Where present, Services and Fire Penetration Seals will require classification values to interact with the FireStoppingRequirements.xlsx.
Parameters View
Walls filter: Defines the compartmentation walls to have fire seal gross and net areas reported.
Floors filter: Defines the compartmentation Floors to have fire seal gross and net areas reported.
Pipes and Ducts filter: Defines service components to have their areas subtracted from the fire seals gross area to calculate the net area of the fire seal.
Cable Carriers filter: Defines service components to have their areas subtracted from the fire seals gross area to calculate the net area of the fire seal.
Fire Seals filter: Defines the fire seal components to have gross areas and net areas checked positions checked.
The rule categorizes low () severity results by the Fire seal ID of the fire seal(s) to report their gross and net areas and volumes along with transferring these values to custom Info parameters that can be scheduled using an Information Takeoff.
Please be aware that the custom info values generated at the time of evaluating the rule are not saved with the fire seals on closing the file. Please remember to re-run this rule again in each subsequent session in order ensure the values are present. The rule can be re-run by simply changing one of the filter values from Include to either Exclude or Ignore and then back again to Include.
Severity:
