The creation of company extensions is only available in Solibri Premium.
Company extensions can be used in both Solibri Advanced and Premium.
All public extensions are available in Solibri Advanced and Premium.
Extensions provide a convenient cloud-based solution for delivering additional resources to the user for tools, such as COBie or custom solutions. An extension can include Rule Templates, Rulesets, Classifications, ITO Definitions and many other resource types. There are two types of extensions:
Company extensions: Companies may need to compile and distribute their own set of resources (rulesets for country-specific regulations, classifications, ITOs etc.) and this can be done with an extension. Company extensions provide a simple method to package and store your own extensions - extension files can be created in Solibri's Extension Manager and uploaded into the Solibri Center from the my company extensions, where they will be available for users to install on their own machines via assignments in SSC.
Public extensions: Additionally, there are public extensions that are available to all users of Solibri (from version 9.13.0 onwards).
For more information on how to install and use extensions. See Installing and Using an Extension in Solibri Advanced and Premium.
Here are all the public extensions available in Solibri (v9.13.0 onwards):
Table 2. Public extensions
Name |
Description |
ADA and ABA Accessibility July 23 2004 |
The ruleset includes a few rules according to standard ADA and ABA Accessibility July 23 2004. |
Allgemeiner BIM Check (ABC-Regelsatz) |
A general BIM check created by Solibri DACH. Only available in German. |
BIM base IDS check essentials |
Easily check the quality of a BIM model with this super simple BIM base IDS check. The extension has a unique approach, based on years of experience with BIM implementations and over 1000 trained Solibri users. The extension is offered by Based, a certified Solibri Training Partner in the Netherlands. More info here. |
BIM Basis ILS v1_3 |
With this extension, IFC models can be tested against the BIM basic information delivery specification (ILS). Only available in Dutch. |
Bim Coordination + |
This extension contains 17 rules that are primarily concerned with provision for Fire Stopping checks but also provides the Stud Opening Check rule. |
Classification IFC4 |
Only available in German. More info here. |
CO2e Calculation |
This extension can be used to calculate CO2 equivalent value. |
COBie Platform |
The COBie extension to Solibri Model Checker provides the most effective process available to collect, validate, visualise, and export COBie information. The extension contains the COBie view and functionality. In addition you also need to download the resources for your local requirements - currently COBie UK or COBie US. |
COBie UK Resources |
Includes rulesets that verify and validate the COBie information in the model, based upon UK requirements. Additionally, related classifications, information takeoff templates and COBie report settings are included. Note: Installation of the COBie Platform is required. |
COBie US Resources |
Includes rulesets that verify and validate the COBie information in the model, based upon US requirements. Additionally, related classifications, information takeoff templates and COBie report settings are included. Note: Installation of the COBie Platform is required. |
CC-ANSI A117.1-2009 Accessible and Usable Buildings and Facilities |
The ruleset includes a few rules according to standard ICC-ANSI A117.1-2009 Accessible and Usable Buildings and Facilities. |
ISO DIS 21542 Accessibility and Usability of the Built Environment |
The ruleset includes a few rules according to standard ISO DIS 21542: Accessibility and Usability of the Built Environment. |
Laajuuslaskelma |
Includes the resources required for area calculation on BIM models in Finland. |
Musterbauordnung_MBO |
This set of rules including the associated classifications was created on the basis of the Model Building Code (MBO). It can be used to check the data requirements and information of your project as required by the MBO. Not only an ideal plausibility check, but also a helpful support for compliance with the law. This rule set (Version 1) is based on the IFC4 - 4.0.2.1 classification. It is subject to a disclaimer. There is no claim to completeness and/or correctness. Furthermore, the rule set may not be handed over to third parties. (only available in German) |
Normativa Urbanistica Capt 8.5 |
This extension analyses the Spanish Urban Code Requirements for Chapter 8.5 |
NS 3940: Area and Volume Calculation |
This extension implements area calculation according to the Swedish SS 21054:2009 standard. It calculates BTA, BRA and NTA values of the rooms and visualization these areas. The calculated areas are assigned as property set to the spaces. They can then be reported using standard Information Takeoff functionality or Fi2XML format. |
Onmisbare BIM basis ILS check |
More info here (in Dutch). |
SIS Area Calculation |
This extension implements area and volume calculation according to the Norwegian NS 3940 standard. It includes classification of spaces to different functional areas plus calculation and visualization of the standard areas. The calculated areas are assigned as property set to the spaces. They can then be reported using standard Information Takeoff functionality. |
Statsbygg BIM Manual |
Statsbygg BIM Manual extension implements Rulesets generated according to ”Statsbygg Building Information Modelling Manual – version 1.2.1” which contains Statsbygg’s generic requirements for Building Information Modelling (BIM) in projects and at facilities. |
Stud Opening Clash |
The rule identifies clashes between services and wall framing components that are not usually modelled. The rule requires Solibri 9.12.9 or later. More info here. |
Suva - Use Case Absturzsicherheit |
More info here (in German). |
Yleiset Tietomallivaatimukset (Finnish BIM Requirements) |
The rulesets are made according to Finnish BIM Requirements published by Building Smart Finland. Note that rulesets are in Finnish and they use SMC Classifications included in Finnish installation (you have to be installed SMC in Finnish before using these rulesets). |
