Classifications Formulas are available in Solibri Advanced and Premium, with full editing access.
The Formulas function is available in Solibri version 25.3 and later, powerful functions can be used to enhance workflows in ITOs and Classifications.
Classification columns are labelled with letters (A, B, C, etc.) to help identify columns when writing formulas.
Formulas in Classifications allow dynamic values instead of static text. In Classification Name, users can choose between:
Text Value - this is the default option and the text is entered manually
Formula - this is a new option for dynamic values
The formula field always starts with an equals sign (=), which cannot be removed or edited.
As you type, auto-suggestions appear, filtering available column names and suggesting supported functions.
When selecting a function, it is inserted with parentheses, and the cursor is placed inside the first parenthesis for easy input.
When a new column is added it will be positioned to the left of an existing column.
This might shift the lettering of existing columns (e.g., what was previously "B" may become "C").
However, formulas automatically adjust and retain references to the correct columns.
This also applies when reordering columns—formulas remain intact despite changes in column positions
Table 3. Logic Functions
Function |
Description |
AND |
Returns TRUE if all arguments are true. Syntax: AND(value1; value2; ...) |
IF |
Returns one value if a condition is true, another if false. Syntax: IF(condition; value_if_true; value_if_false) |
IFERROR |
Returns a value if an expression results in an error. Syntax: IFERROR(value; value_if_error) |
NOT |
Returns the logical negation of an argument. Syntax: NOT(value) |
OR |
Returns TRUE if any argument is true. Syntax: OR(value1; value2; ...) |
Table 4. Math Functions
Function |
Description |
ABS |
Returns the absolute value of a number. Syntax: ABS(number) |
ACOS |
Returns the arccosine of a number. Syntax: ACOS(number) |
ASIN |
Returns the arcsine of a number. Syntax: ASIN(number) |
ATAN |
Returns the arctangent of a number. Syntax: ATAN(number) |
ATAN2 |
Returns the arctangent of the quotient of two numbers. Syntax: ATAN2(x number; y number) |
AVERAGE |
Returns the average of a list of numbers. Syntax AVERAGE(number1; [number 2]...) |
COS |
Returns the cosine of a number. Syntax: COS(number) |
DEGREES |
Converts radians to degrees. Syntax: DEGREES(angle) |
CEILING |
Rounds a number up to the nearest integer. Syntax: CEILING(number) |
FLOOR |
Rounds a number down to the nearest integer. Syntax: FLOOR(number) |
INT |
Returns the integer part of a number. Syntax: INT(number) |
MAX |
Returns the maximum value from a list. Syntax: MAX(number1; number2; ...) |
MIN |
Returns the minimum value from a list. Syntax: MIN(number1; number2; ...) |
MOD |
Returns the remainder of a division operation. Syntax: MOD(number; divisor) |
PI |
Returns the value of π (pi). Syntax: PI() |
POWER |
Raises a number to a specified power. Syntax: POWER(base; exponent) |
PRODUCT |
Returns the product of a list of numbers. Syntax: PRODUCT(number1; number2; ...) |
RADIANS |
Converts degrees to radians. Syntax: RADIANS(degrees) |
ROUND |
Rounds a number to a specified number of decimal places. Syntax: ROUND(number; num_digits) |
ROUNDDOWN |
Rounds a number down to a specified number of decimal places.Syntax: ROUNDDOWN(number; num_digits) |
ROUNDUP |
Rounds a number up to a specified number of decimal places. Syntax: ROUNDUP(number; num_digits) |
SIN |
Returns the sine of a number. Syntax: SIN(number) |
SQRT |
Returns the square root of a number. Syntax: SQRT(number) |
SUM |
Returns the sum of a list of numbers. Syntax: SUM(number1; number2; ...) |
Table 5. Text Functions
Function |
Description |
CONCAT |
Concatenates multiple strings into one. Syntax: CONCAT(text1; text2; ...) |
EXACT |
Checks if two strings are exactly the same. Syntax: EXACT(text1; text2) |
FIND |
Returns the position of a substring within a string. Syntax: FIND(substring; text; start_num) |
FIXED |
Formats a number as text with a fixed number of decimal places. Syntax: FIXED(number; [decimals];[no_commas]) |
LEFT |
Returns the left part of a string. Syntax: LEFT(text; num_chars) |
LEN |
Returns the length of a string. Syntax: LEN(text) |
LOWER |
Converts a string to lowercase. Syntax: LOWER(text) |
MID |
Extracts a substring from the middle of a string. Syntax: MID(text; start_num; num_chars) |
PROPER |
Capitalizes the first letter of a string and converts the rest to lowercase. Syntax: PROPER(text |
RIGHT |
Returns the right part of a string. Syntax: RIGHT(text; num_chars) |
TRIM |
Removes leading and trailing spaces from a string. Syntax: TRIM(text) |
UPPER |
Converts a string to uppercase. Syntax: UPPER(text) |
VALUE |
Converts a string to a number. Syntax: VALUE(text) |
Table 6. Validation and Info Functions
Function |
Description |
ISBLANK |
Checks if a value is blank. Syntax: ISBLANK(value) |
ISLOGICAL |
Checks if a value is a logical value (TRUE or FALSE). Syntax: ISLOGICAL(value) |
ISNONTEXT |
Checks if a value is not text. Syntax: ISNONTEXT(value) |
ISTEXT |
Checks if a value is text. Syntax: ISTEXT(value) |
ISNUMBER |
Checks if a value is a number. Syntax: ISNUMBER(value) |
CHOOSE |
Returns a value from a list based on an index number. Syntax: CHOOSE(index_num; value1; value2; ...) |
Table 7. Operators
Function |
Description |
Addition: Adds two values. Example: 5 + 3 → 8 |
Concatenation: Joins two strings together. Example: "Hello" & " World" → **“Hello World”` |
Division: Divides one number by another. Example: 10 / 2 → 5 |
Equality: Checks if two values are equal. Example: 5 = 5 → TRUE |
Greater Than or Equal: Checks if one value is greater than or equal to another. Example: 3 > 5 → FALSE |
Less Than: Checks if one value is less than another. Example: 2 < 10 → TRUE |
Greater Than or Equal: Checks if one value is greater than or equal to another. Example: 3 >= 5 → FALSE |
Less Than or Equal: Checks if one value is less than or equal to another. Example: 7 <= 7 → TRUE |
Multiplication: Multiplies two values. Example: 4 * 3 → 12 |
Not Equal: Checks if two values are not equal. Example: 8 != 5 → TRUE |
Power: Raises a number to a power. Example: 2 ^ 3 → 8 |
Subtraction: Subtracts one value from another. Example: 9 - 4 → 5 |
