This article explains how to install Solibri Office on a computer. Since Solibri Offline is machine-specific, you need to create a fingerprint file for each computer separately. The file is used to generate the Offline license in Solution Center. Finally, the license file is imported into Solibri.
When you have received the confirmation for Solibri Offline, you can see that an offline pool has been created for you in Solution Center and the Offline Licenses tab in SSC is enabled. You can now start the installation process.
First, you need to create a fingerprint file:
Install Solibri into the computer which is going to use Solibri Offline.
Open File Explorer, browse to open the Bin folder and then the Offline licensing tool.exe file:
The Offline Licensing Tool opens:
Click Save Fingerprint.
The fingerprint file is created and you receive a notification:
If necessary, use for example a USB flash drive to save the fingerprint file so that it can be uploaded to SSC.
Next, the admin of the company account needs to generate the license for the fingerprint:
Sign in to SSC with your admin credentials.
Go to the Offline Licenses tab:
Select the offline license pool.
Upload the fingerprint file.
Add a description. The description is shown in the User License Details tab:
Click Generate Offline License.
A notification opens. To download the license file, click Download Offline License:
Save the license file:
Use for example a USB flash drive to import the file to the Offline Licensing Tool on the offline computer.
To close the notification, click Close.
Last, you need to import the license file to the offline computer:
Since the offline license is not user-specific, you can't sign in with your credentials and you need to set the user information manually. Once the offline license has been imported successfully, you can open Solibri and enter the information for username, reporting identity and organisation.
