All IDS Editor features are exclusively available in Solibri Advanced and Premium.
The IDS Editor provides the Entity, Property, and Attribute facets in Solibri Essential.
This article describes how you can create an IDS file in Solibri IDS Editor. You can choose to either create the IDS file from scratch or upload a previously created IDS file and edit it. When you've completed the specifications, you can download the file in <filename>.ids format.
In the first section, you can add information related to the project. This is the metadata part of the IDS file. You can add the following information:
Title: The document title of the IDS. This is a required field.
IFC Version: The IFC standard version. Available versions are IFC 2x3, IFC 4 and IFC 4.3.
File Version: You can provide a unique identifier to version your IDS files.
Author: The author of the IDS File. By default, this is pre-filled with your email, but the field is editable.
Creation date: The date the file was created. Please note that this is not a timestamp and you can edit the field.
Description: You can add a description of who the IDS is for, why it's created, what projects it might apply to, etc.
When you create an IDS file with the Solibri IDS Editor, an XML comment is automatically added to the file. This comment provides crucial metadata that facilitates better traceability and documentation. It includes specific details, such as the software version, timestamp, and other relevant data. The XML comment ensures that any future reference to these files will be clear and well-documented.
If you have created an IDS file or an Excel file, you can upload it to the Solibri IDS Editor, make changes and download the edited file. Note that this action will clear the IDS file you're currently working on and replace it with the imported content. To upload an IDS file:
Click Upload IDS file:
A dialog opens. If you wish to download the current IDS, click Current IDS. To upload an IDS file, click Clear current IDS:
Import an existing IDS definition either from an `.ids` file or from an ".xlsx" Drag and drop the file into the dialog (or browse the file)
From this dialog, you can also download the IDS Excel Template and open the Excel Template Guide, which describe the supported structure for authoring IDS content in Excel. After you have completed all parameters in the Excel template, simply drag and drop the file into the dialog and the IDS Editor will be prefilled with your content.
The file is opened.
The import will fail if you try to import an IDS file which doesn't include the ids: prefix.
When you open the Solibri IDS Editor, an example specification has been created for you.
You can add multiple specifications to one IDS file. To add a new specification, click Specification. You can also duplicate an existing specification and add instructions related to the specification:
Specifications are created to be easily understood by humans. However, because IDS files are machine-readable, the specifications are also highly structured, allowing computer software to automatically and accurately verify information requirements without ambiguity. Every specification has four main parts:
Description: A description of the reasoning behind the specification, along with instructions on how to implement it. This section is intended for humans to read and understand the purpose behind the information being requested.
IFC Version: Specify the IFC standard versions you wish to support. Available versions are IFC 2x3, IFC 4 and IFC 4.3
Applicability: Defines the subset of the model that is targeted by the specification. While IFC models contain various types of objects, each specification applies only to a specific subset. This subset can be identified using available facets, such as entity or classification.
Requirements: Specifies the information required for the subset identified in the applicability, such as required properties or materials.
Applicability and requirements are defined using a collection of facets. Each facet represents specific information that a single entity, such as a wall, door or window, in a model may possess. A facet precisely describes this information through fixed facet parameters, ensuring computers can accurately interpret the required data.
When used in the Applicability section, a facet describes the information used to identify the relevant parts of the model. When used in the Requirements section, a facet describes the information constraints the model parts must fulfill to comply with the specification. You can combine multiple facets together to describe a wide variety of specifications. Some facets may have optional facet parameters.
There are six different types of facets:
Entity: Facet parameters are IFC Class and Predefined Type
Attribute: Facet parameters are Name and Value
Classification: Facet parameters are System and Value. You can also load a this facet and populate validated terms from bsDD.
Property: Facet parameters are Property Set, Name, and Value. You can also load a this facet and populate validated terms from bsDD. In Soibri IDS Editor, Custom Property Set is handled as a special case of the Property facet.
Material: Facet parameter is Value. You can also load a this facet and populate validated terms from bsDD.
PartOf: Facet parameters are Relationship and Entity.
The Solibri IDS Editor connects to the buildingSMART Data Dictionary (bSDD) and populates standardized information by providing additional facets for Material, Classification and Properties from bsDD.
In the Applicability Section, you can select the set of items to which the requirements are applied. You can add a new Facet to the section by clicking "+ Applicability" button.:
In the Requirements Section, you can specify the requirements. You can add a new requirement by clicking "+ Requirement" button.. Note that it's not possible to reorder the facets once you've added them. If you wish to add a description for the requirements, click the three dots and select Add description:
You can combine multiple facets in either the Applicability or Requirements section to define a wide range of specifications. Some facets may include optional parameters. You can, for instance, define a list of acceptable values, a numerical range, or a text pattern for certain facet parameters. These are referred to as Complex Restrictions.
For some facets, additional options (Add instruction, Add value) are available when you click the three dots:
For detailed descriptions and explanations of the different facets and complex restrictions, as well as instructions and examples, please see the GitHub documentation.
To learn more about Regex patterns, please see here. Please note that in Solibri IDS Editor, the character * (asterisk) by itself is not a valid pattern ,and using it will result in an error. Unlike in Solibri Desktop products, where the characters +, ? and , can be used as wildcards characters without defining a valid regex pattern, IDS requires a valid regex pattern, for instance /.*/, to match any character 0 or more times.
When you've finalized the specifications and the IDS is ready, you can download the .ids file. To do so, click the IDS File button:
If the download button is disabled, some required information is still missing from the specifications. The missing fields are highlighted in red:
When you have finalized the specifications and the IDS is ready, use the Download button in the toolbar to export your work. The menu offers two options from the same place: IDS File for downloading the `.ids` file, and PDF Report for generating a detailed PDF for documentation or use as a contract attachment.
Notice
If the Download button is disabled, some required information is still missing. The editor highlights missing fields in red so you can quickly complete them and then repeat the download.
