This article describes how you can install Solibri Extensions inside Solibri Office that have been purchased in the Solibri Solution Center. As Solibri Extensions are installed inside Solibri Office, local administrator rights for the computer are not typically required.
Solibri Extensions provide a convenient cloud-based solution for delivering additional resources to the user for tools such as COBie or custom solutions. An extension can include Rule Templates, Rulesets, Classifications, ITO Definitions and many other resource types.
Prior to installing in Solibri Office, a Solibri Solution Center (SSC) administrator must have purchased and assigned the relevant licences to the user.
To install a Solibri Extension:
Launch Solibri Office:
Go to File > Solution Center to see the Extensions you have available and their status (Install, Update or Uninstall).
Click Install and wait for the process to complete. You can then continue to use Solibri Office.
This article describes how you can make use of the Resources installed by a Solibri Extension. Solibri Extensions provide a convenient cloud-based solution for delivering additional resources to the user for tools such as COBie or custom solutions. An extension can include Rule Templates, Rulesets, Classifications, ITO Definitions and many other resource types.
The number of possible Resources that may be included with a Solibri Extension varies significantly. Unlike the standard Resources that install with Solibri or are available through a company network, Solibri Extension Resources are available through their own tab within each of the relevant dialogs (Rulesets, Classification or ITO Definitions etc).
Example: Loading a Ruleset from a Solibri Extension
In this example, we will use the COBie UK Resources that work in conjunction with the COBie Platform.
Launch Solibri Office and open your model(s)
Go to the Checking Layout
In the Checking View ,click the Add Rulesets button
Click the Resources tab that has been added by the Extension
Select the Ruleset(s) you wish to add to the Project
Click Open
Continue to use Solibri Office
