Products and Extensions for Solibri are purchased (many with no cost) through the Solibri Solution Center. However, only users with administrator or buyer rights can do this. A regular user without the necessary rights will see the following:
As a regular user there is no access to the Admin View or the ability to purchase items (the Buy option on products and extensions is replaced with Wish and the Shopping Basket is not visible.
If you need to purchase a Product or Extension but do not have the necessary rights, you need to contact your Solution Center administrator.
If you pay by invoice, you will receive an invoice within three business days. Once the payment has been completed, the Product(s) and Extension(s) are added to your account. You can then sign in to the Solution Center and go the Assignment tab to assign product licenses to users.
Purchasing a Product or Extension is a very simple process – in the following example, we will purchase a free Extension:
Sign into Solution Center
Go to the Products view
Select the operating system from the drop-down menu (MacOS, Windows 32-bit, Windows 64-bit and MSI 64-bit are available)
Select Solibri Extension from the drop-down menu (Product, Solibri Extension and Training and Documentation are available)
Scroll through the list and add COBie Platform and COBie UK Resources (or any examples) to your cart by clicking the dark blue button showing the price or Free:
Wishes show the administrator which Products and Extensions users would like to have. If a user has wished for a Product or an Extension, a Wish button appears next to the item. To see the wish list, click X Wish(es) as highlighted in the example below:
Once you have added all the products and extensions you want to buy, click
to open a new dialog showing the shopping cart contents.
In the shopping cart contents, you can see the products or extensions you have selected:
You have the option to adjust the number of items in the shopping cart. If you wish to remove a product or an extension from the shopping cart, click Remove. If you need to add more products or extensions to the shopping cart, click Return to Shop.
For free Extensions that will be used in a company account we recommend purchasing Extensions for each user rather than each Solibri licence. For example, a company may have 3 x Solibri Office licences with 12 users – in this case, 12 or more Extensions should be purchased.
To proceed, click Next.
If you selected only free products or extensions,
the Confirm order page appears where you can review your order. If you wish to modify the order, you can Return to shop. To complete the order you must click to confirm you have read the Terms and Conditions then the Confirm button will activate to allow you to proceed.
After confirming, the page will redirect to the Assignment tab within the Admin View where Products and Extensions can be assigned to users
If payment is required after step 8:
The dialog will allow you to provide your invoice details then click Next to view the Confirm order page appears, where you can review your order. If you wish to modify the order, you can Return to shop. To complete the order you must click to confirm you have read the Terms and Conditions then the Confirm button will activate to allow you to proceed:
After proceeding and completing the purchase, an Invoice purchase confirmation is displayed:
